The short answer is YES.
A little longer answer is that you will want to move all your bolt-ons from your original 91 Celica 4A-FE to the 93 Corolla 4A-FE (intake manifold, A/C unit & brackets, water outlet housing, etc., etc., etc.). Just look for anything that is slightly different between the two engines, and where there is a difference, use your Celica parts. Since you will reuse all the bolt-ons from your original Celica, you can continue to use your Celica's ECU and wiring harness.
Is your state an emissions testing state?
Reason I ask this last question is that I think the EGR setup on the Corolla is different that what is used on the Celica. I believe the Corolla head does not have the extra port the Celica head has for the Celica EGR system (because of the difference in the intake manifold, and you will want to reuse your Celica's intake manifold). So if you don't have a working EGR system after the engine swap, you won't pass an emissions test, if that is something you have to worry about.
I swapped out an engine from a 90 Celica ST 4A-FE with one from a Corolla, and the only difference was the EGR port missing in the Corolla head. But, the car was in Wisconsin, now Iowa, no emissions tests, so no problem.
