To what end?
Most of the anti smog comes from the cams, horribly retarded ignition and catalytic converters (off the top of my head I can't remember which year and which parts of the US got stuck with cats - thankfully we didn't get them until years afterwards here in Australia).
The ignition timing can be fixed tuned around.
The cams would have to be replaced.
Cats you're stuck with.
Most of the vacuum system is to do with cold starting - which is when most pollution occurs.
Will you run foul of any laws?
If you're just after more power then try these methods:
- tune up (fresh plugs and good timing does wonders for old engines)
- better exhaust headers with better mufflers (preferably 2" straight through with relatively stock engine,
- replace carb with Weber 34 carb
- replace the cams and retune
- replace 20R with 22R (even better if you keep the 20R head for raised compression
Disclaimer - here in Australia we never got the 20R but these tricks have had good reports by friends in the US and similar tricks have worked well for my 1977 18R-G Celica (aggressive cams, totally new 2.5" exhaust, Weber sidedraft carbs).
- Stepho
