MoonRoof 1990 celica - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-21-2010, 12:24 PM   #1 (permalink)
View crimson11's Photo Gallery
moonroof does not work rep the mortor still doesnt work but i can't remove the panel to see if it rust causing it from not working how do i remove the moonroof panel pic would be helpfull. ive seena relay next to the moonroof mortor where can i find that and if you know the $ =_=
crimson11 is offline   Reply With Quote
Old 07-21-2010, 12:48 PM   #2 (permalink)
Gameroom cash: $139205
View 93celicaconv's Photo Gallery
What does "rep the motor" mean?
What panel exactly do you want to remove? The entire sunroof sliding panel assembly? The headliner panel? The switch cover / access to the motor and relay panel?
What kind of electrical testing have you already done regarding the motor, control switches, and relay? Do you have electrial testing capability?
I have heard of a control relay failure on these setups. A new one from Toyota costs around $500. I found one in a salvage yard for someone looking for one in Hawaii, which turned out to fix his problem. If you electrically diagnose the control relay and find it does not test out properly, I would advise you look for one from a nearby salvage yard - as I think this simple control relay is a bit cost prohibitive.
93celicaconv is offline   Reply With Quote
Old 07-21-2010, 02:29 PM   #3 (permalink)
replace moonroof mortor just under the front ligth dome,fuse check out none burnt out relay switch clicking sound and nothing else testing= red wire blue wire cut
Old 07-21-2010, 03:04 PM   #4 (permalink)
OK, you hear the relay clicking - do you hear the motor groaning or at least trying to move? Does the tilt up function work? Does the slide back feature work? Either or both?
What does "testing = red wire blue wire cut" mean?
Old 07-21-2010, 04:59 PM   #5 (permalink)
it does try to move but it doesnt. as for the other 2 question neither
Old 07-21-2010, 09:35 PM   #6 (permalink)
I'm sorry, but we are on different playing fields, aren't we?
My question was related to what you hear. You said you here the sunroof control relay clicking. Do you hear any noise coming from the motor as if it is trying to move, but is stalling out? Have you ever heard a motor that was held in a stall situation...it tries to turn, hums all the time, but it just can't break free and start turning? That is the kind of sound I'm asking if you are hearing, beside the control relay clicking.
Do you?
