new 88 celica gts need some help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-27-2010, 10:52 PM   #1 (permalink)
View drawsemaj's Photo Gallery
okay so i just bought a 1988 toyota celica gts has a few things i need to fix but it has a idling problem that i really wana take care of first it completely random but the idle rises really fast then drops back down and seams to do this at differant rpm ranges anyone know whats up with it
Currently Own:
Wrecked White 92 Corolla (Parting Out)
Red 88 Celica
drawsemaj is offline   Reply With Quote
Old 08-28-2010, 06:25 AM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
When does it do this and approx what are some RPM values you are seeing?
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 08-28-2010, 10:46 AM   #3 (permalink)
when the engine was cold it was starting at 2000 then jumping to around 3000 then droping back once it was warm it was around 1000 to 1700 and it un the time i was driving last night it never idled lower than 1000
Currently Own:
Red 88 Celica
Old 08-28-2010, 04:25 PM   #4 (permalink)
Do you happen to have any codes pop up?
The first thing I would take a look at would be the Idle air control valve. I had somewhat similar symptoms when mine became unplugged.
Old 08-28-2010, 05:12 PM   #5 (permalink)
how do you check the codes? and the check engine light hasnt come on but i also dont know that it works i just bought the car the night befor last
Currently Own:
Red 88 Celica
Old 08-28-2010, 09:25 PM   #6 (permalink)
when you turn the key to ON, does the light come on? if so, and you dont have the light come on while driving then you dont have any codes. if the light doesn't come on at all when you turn the key to ON then you may have a code just the bulb is blown.
Old 08-28-2010, 09:55 PM   #7 (permalink)
yeah it lit up when i turned it on but it doesnt stay on
Currently Own:
Red 88 Celica
Old 08-28-2010, 10:01 PM   #8 (permalink)
Bitter's Avatar
Gameroom cash: $560100
View Bitter's Photo Gallery
should be able to jump TE1 and E1 with a paperclip to make the engine light flash out any stored codes. May be nothing stored, these are pretty basic systems. is this a flap type mass airflow? sometimes those wear out and give bad readings where the flap moves the most.
Old 08-28-2010, 10:39 PM   #9 (permalink)
yes it is a flapper type mass air flow sensor i just replacedd the air filter since i had one from my corolla that was identical to the one in there does anyone know where i can get the other type of sensor that is also capable of hooking a cone filter to? i would like to completely remove the factory air intake if posible i noticed the first half of it was already removed anyways
Currently Own:
Red 88 Celica
Old 09-03-2010, 03:00 AM   #10 (permalink)
Rick89GTS's Avatar
View Rick89GTS's Photo Gallery
If you can't find a known good AFM to swap in, just try cleaning and checking the connector plug and hold it in snug to see if that helps.
CAUTION: NEVER unscrew the connector plug - it simply unplugs when you push in the metal retainer clip.
Rick89GTS is offline   Reply With Quote
Old 09-03-2010, 05:26 PM   #11 (permalink)
cchecked and made sure all conections were tight and it didnt change the idle any and there arent any of those clips on there right now the last owner rebuilt the engine and must have lost them
Currently Own:
Red 88 Celica
Old 09-04-2010, 04:59 PM   #12 (permalink)
ok so i checked the codes and i believe its throwing code 24 and 41 what do these codes mean?
Currently Own:
Red 88 Celica
Old 09-06-2010, 01:08 PM   #13 (permalink)
Rick89GTS's Avatar
24 - intake air temperature sensor circuit
41 - throttle position sensor circuit or ECU
