91 celica gt w/turbo swap need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2010, 11:59 AM   #1 (permalink)
View juggathony's Photo Gallery
USA 91 celica gt w/turbo swap need help
i have a 91 celica gt w/turbo swap and the exhaust manifold glows bright red after a 10 min drive the car does not read hot on the temp guage there is no thermostat just a restrictor plate did coolant pressure test no leaks
also ran compression test cylinder 1. 180 2. 180 3. 160 4. 160 and also have bubbling sound in overflow tank but am running staraight water
juggathony is offline   Reply With Quote
Old 09-08-2010, 07:49 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
The bubbling sound is normal. It is also normal for the turbine side to glow red, but only after running it for awhile. 10 minutes won't normally do that.
What exhaust are you running? With turbos, it's all about flow.
The Jedi Speeder at CarDomain
Old 09-11-2010, 09:49 AM   #3 (permalink)
View trumanpriest's Photo Gallery
I've heard of people having this exact problem with a clogged cat. Like MR2Jedi said, it's all about flow. If you aren't able to flow the exhaust out properly it will light up the mani bright red.
Trumanpriest - 1990 ST185 | 2010 Tacoma | 2009 Yaris
Cardomain.com/ride/550639
trumanpriest is offline   Reply With Quote
Old 09-12-2010, 10:21 AM   #4 (permalink)
View drawsemaj's Photo Gallery
if trumanpriest is right and you live in an area like oklahoma where you dont have to meet smog regulations and all that i would gut the cat just so you dont have to worry about it
Currently Own:
Wrecked White 92 Corolla (Parting Out)
Red 88 Celica
drawsemaj is offline   Reply With Quote
Old 09-12-2010, 12:26 PM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Note:Remember, gutting your cat is illegal.
BUT, if you do, you will see a faster spool and alittle more HP.
Remember to wear a particle mask and eye protection. The dust from the Cat material is very harmful to your lungs and eyes.
Ultimately, the best solution is a new catless exhaust system-from the turbo to exhaust tip exit.
Old 09-13-2010, 02:01 AM   #6 (permalink)
yeah MR2jedi is right it is illegal in most areas im not sure whether it is here or not but the dont check our cars so untill they do ill be running a gutted cat i need to go ahead and get it dont to my celica before i forget about it
Currently Own:
Red 88 Celica
Old 09-13-2010, 02:08 AM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
We don't test emissions here either. I ran my gutted cat for a few months, then eliminated it and the secondary cat completely.
Now I'm totally catless.
Hopefully, the laws here won't change anytime soon.
Old 09-13-2010, 09:30 AM   #8 (permalink)
^+1, I'm running the same. Good ole Illinois not requiring inspections. Now if they'd just make it so I didn't have to run a front plate I'd be very happy.
Old 09-15-2010, 12:55 PM   #9 (permalink)
View jmk1977's Photo Gallery
If you don't want to run without a cati, get yourself some acetone cut the cat off the pipe clog one end pour the acetone in and slosh it around for a bit, tip it like a rain stick. pour it out on a stump or something, your cat should now be carbon and oil free.
jmk1977 is offline   Reply With Quote
Tags
3sgte, celica, overheating, turbo
