gearbox oil change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-17-2010, 05:06 PM   #1 (permalink)
View st-195's Photo Gallery
gearbox oil change
hi there anyone now how to do a oil change on the manual e56 4wd gearbox?
st-195 is offline   Reply With Quote
Old 09-17-2010, 10:47 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
It's pretty simple.
Remove the drain plug at the bottom of the transmission and drain in to proper container.
Replace drain plug.
Then remove fill plug on side of transmission (a square bolt). Fill with 90wt gear oil to just below the fill hole. Replace fill plug.
I recommend Redline 90wt gear oil.
The Jedi Speeder at CarDomain
Old 09-18-2010, 02:15 AM   #3 (permalink)
drove the car up on some ramps and had a proper look there are two drain plugs one for the gear box section and one for the 4wd diff section i simply drained both sections and filled up to the filler plug which i also found. very easy job the old oil was quite dirty strange how most people never even think of changing their gearbox oil
