Alternator Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2010, 10:22 PM   #1 (permalink)
Awesome ends with me.
John1990's Avatar
View John1990's Photo Gallery
Gen5 Alternator Question
Hey guys, got a question for you if you don't mind.
Trying to take the alternator out of the old sea hag. Disconnected the negative battery terminal. Disconnected the wiring harness, Unscrewed the stud holding the negative lead. Loosened the tensioner bolt. Unscrewed and removed the last bolt from the mounting bracket. The problem is the alternator still won't come off. It seems there is something connecting the alternator to the mounting bracket - a little washer type thingy or ring in the left side of the bracket (passenger's side). Do you know what I am talking about and how to finally get the alternator off of the mounting bracket?
I am looking at a new rebuilt Champion brand alternator from crappy tire for 200 dollars on special this week as opposed to getting a local guy who says he will charge me 60 dollars to "unsieze" my alternator if possible.
1990 CELICA GT 5 SP 260KM, No Air, Orig. Muffler.
2007 Lexus IS 250 AWD. Black Sapphire Pearl. HIDs, Rear Spoiler; Formula 1 Tint, Michellin PS2s on Lexus 18" Chromies, K&N, Lexus GFX Kit, Luminics Pure Blue, PIAA Xtreme White. @ClubLexus.com.
2004 Triple Black Convertible Corvette
John1990 is offline   Reply With Quote
Old 10-01-2010, 11:44 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
If you have the anchor bolt out, it should come out. The base of the Alternator is wedged in tight. You will have to pry it out with a small pry bar.
The Jedi Speeder at CarDomain
The Following User Says Thank You to MR2Jedi For This Useful Post:
John1990 (12-31-2010)
Old 10-03-2010, 11:25 AM   #3 (permalink)
Rick89GTS's Avatar
View Rick89GTS's Photo Gallery
^Yep, pry bar and tap gently with a rubber mallet!
Rick89GTS is offline   Reply With Quote
The Following User Says Thank You to Rick89GTS For This Useful Post:
Old 12-31-2010, 10:09 AM   #4 (permalink)
John1990's Avatar
Thanks guys.
Old 12-31-2010, 11:44 AM   #5 (permalink)
Bitter's Avatar
Gameroom cash: $560100
View Bitter's Photo Gallery
and when installing the new one, you may need to lightly (or not so lightly) file or sand paper the bracket or alternator to get it to slip into place without beating it into submission, helps also to smear a touch of anti-seize on the ear and make sure its good metal to metal contact between the bracket, block, and alternator.
Old 12-31-2010, 10:40 PM   #6 (permalink)
John1990's Avatar
Thanks, Bitter.
