5sfe to 5sfe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2010, 05:01 PM   #1 (permalink)
View enyoceres's Photo Gallery
5sfe to 5sfe
I have a 1991 Toyota Celica GT with a blown 5sfe, and I just bought another 5sfe for a 1992 Mr2. I still have my Celicas wiring harness and ecu but will that work on the 5s i just bought? There are some clear differences in between them (valve cover, intake design, ect) but would i be able to use my old harness and ecu or is it more trouble then its worth and i should just go search for a 92 5sfe ecu and harnass. Also will I be able to use my clutch and tranny with the newer style 5s? Any info would help thanks
enyoceres is offline   Reply With Quote
Old 10-05-2010, 01:25 AM   #2 (permalink)
any thoughts on this anyone i could really use some help or advice
Old 10-05-2010, 07:24 AM   #3 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
You can swap over everything from your old 5s, manifolds, any brackets, your clutch and transmission. You're going from a rev 1 to a rev 2, I'm not entirely sure of all the differences, but I would just use all the wiring and sensors from your old engine. The only one that will be extra IIRC will be on the new engine there will be a knock sensor, when your old engine did not.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 10-05-2010, 04:43 PM   #4 (permalink)
One difference between the rev1 and rev2 that I noticed right away was the flywheel. The on one the rev2 motor has 8 blots into the crank and the flywheel is pretty thin and the rev 1 motor has a heavy flywheel and 6 bolts going into the crank if I remember right
