1.8 (95) engine died, which ones can i use to replace it? (same with transmission) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2010, 05:50 PM   #1 (permalink)
View yoshiki2's Photo Gallery
My engine just died, and the transmission is failling( manual), which engine + tranny should i buy that's easy to install?
yoshiki2 is offline   Reply With Quote
Old 10-04-2010, 06:22 PM   #2 (permalink)
Gameroom cash: $819101
View zythr's Photo Gallery
What shape is the rest of the car in?
zythr is offline   Reply With Quote
Old 10-04-2010, 06:24 PM   #3 (permalink)
good, i just need to repaint the wing, and one part of the body
Old 10-04-2010, 06:48 PM   #4 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
You had a 7afe, that would be the easiest. Direct swap, no changes. It came in the 93-97 Corollas with the 1.8L and 94-99 Celica STs. It is also possile to use a 4afe or even an imported 5afe, but one of the biggest problems is wiring for the fuse box IIRC for the 4afe (not really sure about the 5afe).
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 10-04-2010, 07:01 PM   #5 (permalink)
i thought this was the engine size.. 1.8 L 7A-FE I4, or am imaking any mistakes?
can i place a 1.6? are the transmissions betwen the corolla and celica different?
Old 10-05-2010, 07:37 AM   #6 (permalink)
Yes, you have a 7AFE engine. The 1.6L is a 4A engine. If the celica is an ST model, it will use the same transmission series as the corollas. FWD A seres engines use c Series transmission so the they will bolt up, although the different variants will have different drive ratios inside.
You can replace it with the 1.6L, everything will match up. I haven't found too much regarding the wiring although I seem to remember hearing (this is purely from what I've read, I have not done this so it would require more research) that if you just used the 4AFE longblock and used all the wiring and sensors from the 7afe the ecu will compensate. One thing that may require modification is the exhaust. although if you just use the 7afe exhaust manifold you shouldn't have to change anything, I believe.
