when to change gears when draggin ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-15-2004, 07:37 AM   #1 (permalink)
View Sleeeka's Photo Gallery
what are your thoughts on teh matter ?> i always thought it was on the redline point
whos your daddy ?
89 Celica St162 White Lightning
3s-ge 2.0L
Sleeeka is offline   Reply With Quote
Old 04-15-2004, 08:24 AM   #2 (permalink)
3rd 5-speed Camry...
87Camry5Speed's Avatar
View 87Camry5Speed's Photo Gallery
First, I think this should be moved to hardcore/tech/competition, you'll get more opinions there...
But to answer the question- not necessarily. The only good way to figure this one out is to fool around with your shift points a little and see what works best for you.
I haven't had a car I could put the revs all the way up in yet; for example, the T-bird Turbo Coupe I had was redlined at 6200 rpm on the tach but could only sustain about 5600-5700 safely (BAD valve float!). The Camry I have now is redlined at 6k but I only ever took it to 5800 once... any higher than 5400-5500 on that motor is torture. It simply doesn't breathe well enough top-end.
The point is, you may find you have better acceleration by not winding it all the way out. So go experiment a little *disclaimer- make sure PoPo isn't anywhere near you!*
Steve
'08 Camry LE 5-speed. Stock as a rock.
87Camry5Speed is offline   Reply With Quote
Old 04-15-2004, 11:59 AM   #3 (permalink)
Stoned Touge®
Touge Celica's Avatar
View Touge Celica's Photo Gallery
I have a 91 w/ a 5SFE. Mine takes redline abuse most of the day, everyday. I can feel my power fall off around 5800RPM but redline is at 6250, and my car makes a sweet backfire sound when I redline it. I figured it was worth the extra abuse.
Grip it and rip it...
Touge Celica is offline   Reply With Quote
Old 04-15-2004, 01:08 PM   #4 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
depends on the car and where its power band is.....my redline is 7000 but i always shift at around 6500 to stay right in my peak power band after shifting.....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
