Please see pics... valve timing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2010, 09:03 PM   #1 (permalink)
View 77toyo's Photo Gallery
I've never done a timing belt before and i'm working on my friends' 94 celica gt. I just put the timing belt on and making sure the crank and cam marks line up. Please see the pics to see if the marks look good enough to put everything back on.
below it looks like it's almost in between the 0 and 5 (but closer to 0)
from a different angle, it looks almost under the 0
below you can see the cam notch is aligned perfectly
what do you guys think?? I've already let the tensioner pulley loose to apply tension and re-tightened it. should i just rotate a few times clockwise and see if they're still aligned or what? Thanks in advance
77toyo is offline   Reply With Quote
Old 10-21-2010, 09:58 PM   #2 (permalink)
ok, i think there is something wrong. i believe there is not enough tension between the water pump pulley and the cam pulley. redoing now...
Old 10-21-2010, 11:14 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
After bolting down the tensioner and making the belt very, very tight, turn the crankshaft 2 whole revolutuions back to zero and see if all the marks realign.
The Jedi Speeder at CarDomain
