90 celica gts trans swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2010, 08:50 PM   #1 (permalink)
CELICA GTS
Joe_c25's Avatar
View Joe_c25's Photo Gallery
Hi all.... I have a 90 celica gts. The clutch and trans are going on it. So I started looking at getting a clutch on ebay. I noticed that it not only mattered what year the car was made but also the month. I have a parts car 93 celica gts that i wanted to use the trans off that . So two questions Im desperately hoping someone can help me with.
1. Will the transmission from the 93 celica gts bolt right on to my 90 celica gts
2. If I get the clutch should i get one that is listed for fitting on the 93 celica trans or the 90 celica motor.
oh and the two cars have the exact same motors 5FSE as far as i know. have swapped out steering knuckles ect.. and looked at the drive axles and they are the same.
and the 90 celica i want to have running good was made 02/1990 not the same bracket as
from 05/90 as listed with clutches on ebay. the only difference i could think of was the mounting of the pressure plate to flywheel
most the clutches in both brackets listed are same 20 spline and 225mm dia.
Joe_c25 is offline   Reply With Quote
Old 10-27-2010, 08:23 AM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
It is the same S53 transmission. How many miles are on the parts car?
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 10-27-2010, 11:09 AM   #3 (permalink)
CELICA GTS
Joe_c25's Avatar
Too many 142915m. But I drained the trans oil and it was very clean ... no shaving ..not sticky ect..
Also if it the same trans.. then why would they have different listings of clutches depending on the month it was made.. I called my toyota dealership.. he couldnt tell me too much .. but when he was looking up trans stuff there were different part numbers.. he couldnt tell me what parts were different though.
Old 10-28-2010, 01:42 AM   #4 (permalink)
CELICA GTS
Joe_c25's Avatar
What clutch kit should i get then ... one listed for the 90 motor or one listed for the 93 transmission
Old 10-28-2010, 08:11 AM   #5 (permalink)
View drawsemaj's Photo Gallery
4th Generation
if your using the 93 transmission i would go with a 93 clutch because the splines may have changed
i know that toyota changed them between the toyota corolla and the geo prizm which were both the same car so i always make sure that the clutch disk fits on to the transmission first now lol
Currently Own:
Wrecked White 92 Corolla (Parting Out)
Red 88 Celica
drawsemaj is offline   Reply With Quote
Old 10-28-2010, 08:00 PM   #6 (permalink)
CELICA GTS
Joe_c25's Avatar
Ya thats what I thought but both the different clutches are listed with the same spline and same dia. 225 diam and 20 spline. So I thought something might be different with the pressure plate.. like the mounting holes or something... Anyways Ive ordered the clutch listed for the 93 trans. Just pulling the trans out this week..
Old 11-01-2010, 08:11 AM   #7 (permalink)
View jagger's Photo Gallery
I believe the celicas made in the early 90's, before April 90 used a different release bearing for the clutch. Check your manufacturing date on the driver's door panel. The clutch itself is the same for all celicas 90-93
jagger is offline   Reply With Quote
Tags
93 to 90, celica, clutch, swap, transmission
