1990 5SFE won't go above 4,000 RPM - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-05-2010, 03:57 PM   #1 (permalink)
View int3man's Photo Gallery
Hi all, Daughters car is at it again. It was acting like a fuel issue. Replaced the Air filter, Fuel filter and then the fuel pump. The car runs strong up to 4,000 rpm then goes flat and starts bucking / dropping off. Not throwing any codes.
6 months since top-end Clean; Cap; Rotor; Plugs ...
Take out Motor from Japan with 30,000 +40,000 miles on it.
It was suggested that the CAT was plugged. Car has 207,000 Spoke with local gargae and they said that it would not run past idle with a plugged CAT.
Thanks for any offers of assistance.
1990 5-speed GT 5SFE
int3man is offline   Reply With Quote
Old 11-06-2010, 11:52 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Check ignition timing.
The Jedi Speeder at CarDomain
Old 11-06-2010, 08:47 PM   #3 (permalink)
Timing within Spec's.
I read somewhere that a coolant sensor can raise Havoc and not throw a code?
Old 11-06-2010, 08:54 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Yes, I've heard that, but don't know if it's true.
Old 11-26-2010, 01:41 PM   #5 (permalink)
Hi All, Got it. Car finally got to the point that it would not run. Cat was plugged. Once I temporarily cleaned it out! Car runs Excellent. Shopping for replacement CAT. Thanks for your feedback!
Old 11-26-2010, 01:58 PM   #6 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
A direct fit cat may be rather pricey. For about the same price, you can replace the manifold and cat with a header, buy a universal cat, and have a shop weld it in farther down the exhaust. Something you may be interested in doing?
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
