1979 engine swap options?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-09-2010, 10:40 PM   #1 (permalink)
View wardriod's Photo Gallery
I am trying to decide whether to do a mild to moderate performance rebuild on the stock unit or look to see if I can find a newer, higher output/efficiency engine/trans that will fit without massive modifications. If anyone has experience or information on what would fit, I would be grateful. Thanks.
Dave.
wardriod is offline   Reply With Quote
Old 11-11-2010, 04:55 PM   #2 (permalink)
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
If you want to keep it relatively straight forward then there are only 2 real options:
1. Weber 32/26 carburettor, full 2" exhaust (including headers), upgrade camshaft.
2. Replace 20R with 22R engine.
Can also do both options.
Even better if you put the old 20R head on the new 22R block (raises the compression ratio, which allows you to tune for more power).
http://members.iinet.net.au/~stepho/eng20r.htm
Plenty of shops out there do 20/22R work.
eg www.lcengineering.com
If you do the 22R swap, you can also consider if you want EFI.
Wiring up the EFI computer is not very hard and is otherwise similar to any other 22R swap.
Will need a high pressure fuel pump.
http://members.iinet.net.au/~stepho/celfaq.txt
stepho is offline   Reply With Quote
Old 02-28-2011, 01:43 AM   #3 (permalink)
That_Guy was here...
View yotapower's Photo Gallery
i would keep the 20r head and get a 22r block, do you some reasearch... that 20/22r engin is a popular engin mod for those celicas. im thinking about that for my 77 celica gt. possibly side draft carbs down the road...
FOREVER DRIVEN
yotapower is offline   Reply With Quote
