Celice 2001 gt burning oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-19-2010, 03:21 PM   #1 (permalink)
View benipal's Photo Gallery
Lightbulb Celice 2001 gt burning oil
HI
i have 2001 Celica gt. 200k. changed clutch and transmission recently.
1. celice is burning engine oil (~2 litre in a month). back bumper of the car get black near muffler. oil burn happens mostly when driven on higway speed. when i check the oil gauge, the oil color is black. on street speed everything is perfect. even on highway there is no lack in power or speed. great pickup and can reach 190 km/h. can it be related to timing belt? becuase some mechanic had a look at engine and suggested to change timing belt.
2. other problem is that when on highway speeds. engine jerks sometimes. lets say 3 or 4 times in 200 kms. and sometimes no jerk at all for 120 kms. it seems like engine missed the blast and skips but then runs smoothly again. i have changed spark plugs, oil filter and tried flue injector cleaners.
can it a problem relted to oil/air mixture?
any help will be greatly appreciated
Thanks!
I love my Celica
benipal is offline   Reply With Quote
Old 11-19-2010, 09:19 PM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
Is there any discoloration to the exhaust gases? I would try to do a compression test on it, the first thing I thought of was piston rings.
I wouldn't suspect the timing belt, you may get those symptoms if the belt maybe skipped a tooth, but it would have a dramatic effect on the performance.
Also, are you getting any engine codes?
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 11-21-2010, 06:25 PM   #3 (permalink)
Official TN Toaster
iToaster's Avatar
Gameroom cash: $349795
View iToaster's Photo Gallery
2001 GT's burn oil like crazy, it's a mechanical fault of the engine related to the piston rings, the only solution is to put an engine from 2003 onwards in it. There is not a timing belt on your engine, it is a timing chain and shouldn't need to be replaced. Can't say much about your other problem, but you might want to look into replacing your air filter and cleaning the mass air flow sensor.
1995 Corolla DX - 7A-FE - 5 Speed - 8K1
2000 Celica GT-S - Supercharged 2ZZ-GE - 6 Speed - 3P0
RIP white Corolla
iToaster is online now   Reply With Quote
