92 Celica Frost Plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2010, 05:38 PM   #1 (permalink)
View celicaman2010's Photo Gallery
Hi, Can antone tell me where the frost plug is located in a 92 Celica Pop up lights model?
celicaman2010 is offline   Reply With Quote
Old 12-01-2010, 07:49 PM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
There are several free plugs. All are located about half way up the engine block. Look up from underneath to see them best.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 12-04-2010, 05:08 PM   #3 (permalink)
Would there be one underneath the alternator? about 5mm in size , maybe a little more
Old 12-04-2010, 05:38 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Freeze plugs are much larger than that.
The Jedi Speeder at CarDomain
Old 12-04-2010, 09:02 PM   #5 (permalink)
Yes, like I said look up underneath and on the sides of the engine. you'll see a few about 40-50mm or so in diameter (IIRC) if this is an S series engine, do you have the 2.0L or the 1.6L
Old 12-05-2010, 03:38 PM   #6 (permalink)
It's a 2 liter GTI , there is a small hole in the engine block
Old 12-05-2010, 05:08 PM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Is there anything leaking from this hole?
Old 12-05-2010, 05:20 PM   #8 (permalink)
These.
There are some on the front side as well like these
Like MR2Jedi asked, are you leaking coolant or just have a leak in something in general?
Old 12-06-2010, 04:04 PM   #9 (permalink)
The weather here has been freezing so I drained the radiator but now I've discovered water leaking from a small hole underneath the alternator on the engine block.
Old 12-06-2010, 05:24 PM   #10 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Is the hole threaded?
If so, it may be the block coolant drain and you've lost the bolt that plugs it.
Old 12-07-2010, 04:26 PM   #11 (permalink)
not sure most have a look tomorrow sound.
Old 12-07-2010, 05:17 PM   #12 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
