Transmission trouble... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-06-2010, 06:01 PM   #1 (permalink)
View Danielsc's Photo Gallery
USA Transmission trouble...
Hello all, I have a 1990 Celica with a 1.6 motor auto trans. Ok gears changed just fine until cold weather got here. Now gears change fine, but won't go into high gear until motor is warm or after run a mile or so. Need help here on what to do. Thanks for any help on what to do... !!
Danielsc is offline   Reply With Quote
Old 12-14-2010, 12:09 PM   #2 (permalink)
View jeepdan77's Photo Gallery
Toyota automatic transmissions are set up in 2 ways. The 1st way is when the engine reaches a certain temp it'll allow it to go into overdrive. The other setup is when the transmission reaches normal temp it'll allow it to go into OD. Take notice as to the temp of your engine when it final shifts into high gear. If its the same every time then you'll know why. Now also check the level of your transmission fluid, if it's too low it'll take awhile for the fluid to heat up before expanding enough to engage OD.
jeepdan77 is offline   Reply With Quote
Old 12-14-2010, 04:44 PM   #3 (permalink)
Thanks for the reply ! So this is normal for a transmission with a Over Drive button ? That sounds good to me ! Yeah change's at time when engine warms then its fine. I've ask advance auto and orthers and no one knew ... And asked a transmission shop and he said it maybe had some kinda heat switch that would let it know when to change when cold weather ... maybe , so hope your right ! Don't have the money for transmission probs. now !
Old 12-14-2010, 11:33 PM   #4 (permalink)
It's annoying but normal, it'll really annoy you on very cold days where it takes your car forever to warm up. I can't say if newer Toyota's are this way but I've owned many late 80's to mid 90's and all them do it in the winter. I drive a lot of highway speeds and mine will be in 3rd gear for almost 5 minutes when it's below 0 degrees before it's warm enough to change into 4th.
