Weapon r sri 00 celica - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-06-2010, 09:25 PM   #1 (permalink)
View xjuliusxx's Photo Gallery
Ever since i put in my sri for my 00 celica gt, my gas mileage dropped way more than it should. The installation instructions were very confusing. I have one sensor not plugged into anything simply because theres nothing to plug it into. can anyone help me out?
oh and my engine check light isnt on so idk what the problem is
xjuliusxx is offline   Reply With Quote
Old 12-06-2010, 09:47 PM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
Did the sensor that is currently unplugged go into the stock intake between the filter and the throttle body? IIRC right behind the filter?
There should be either an Air Intake Temperature sensor, mass air flow meter, or it may be a combo air flow meter/AIT sensor. If this is not plugged into the intact tract the ECU will not recieve correct information about the air flow and will not have the optimal air/fuel mixture. A lot of times on these intakes a hole has been drilled or has to be drilled for these sensors.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 12-06-2010, 09:52 PM   #3 (permalink)
well it wasnt the MAF sensor but yeah i think it did go into the back of the stock box. but if i drill a hole in the intake, do i just screw the connection onto the intake? or does it go inside?
Old 12-06-2010, 10:17 PM   #4 (permalink)
I would have to see the sensor to tell. I dont personally own a car with this engine. If you could take a picture that would help greatly
Old 12-06-2010, 11:31 PM   #5 (permalink)
alright ill try to get a picture up asap. thanks alot i appreciate you helping me out
Old 12-07-2010, 03:39 PM   #6 (permalink)
sorry for the huge pictures i didnt meant to make them that big i just want to make sure you see it:
this is my setup... the MAF is under instead of above it wouldnt fit any other way:
THIS is the sensor which i have no clue where to put it...:
this is what i believe the sensor plugs into but i dont know where i would put it...:
Old 12-07-2010, 10:13 PM   #7 (permalink)
.... I dont see any pictures
Old 12-08-2010, 07:30 PM   #8 (permalink)
can you see them now?
Heres my set up:
The mysterious sensor:
This is what i believe it plugs into from the stock box. but I dont know how i would put it on the intake:
Old 12-08-2010, 07:59 PM   #9 (permalink)
Well it looks like a vacuum sensor/switch, after a little searching around I found this:
http://thematrixgarage.com//YaBB.pl?num=1251224855
Hopefully this will lead you in the right direction.
Also, I recommend resetting the ecu so that it can learn new fuel mapping based on your intake. Just disconnect a battery terminal and wait 5 minutes or so, then reconnect.
EDIT: I also found this
photocredit: trimovingxr
Old 12-08-2010, 11:52 PM   #10 (permalink)
thank you so much! the pic looks like it has way more wires than my short ram came with. but ill try resetting the battery
