Need heellpp - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-08-2010, 03:17 PM   #1 (permalink)
View mikey m's Photo Gallery
Need heellpp
im having a serious problem. ok i bought a 94 celica gt it was fine i bought alot of BRAND new parts for it and i keep having an overheating problem and idk what it could be i ran out of solutions i bought a braqnd new thermostat which it needed and brand new radiotor and radiotor cap brand new water pump and i ran out of options so someone please help me figure out this problem...
mikey m is offline   Reply With Quote
Old 12-08-2010, 04:24 PM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
Could have been low on coolant with a large air pocket. Also are you sure the new thermostat isn't defective? Once the engine is brought up to temperature, do you get coolant flow?
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 12-09-2010, 03:27 PM   #3 (permalink)
no we thought it was an air pocket and when we drained it and try to do it over again it was filling up and when the mototr was heated up it started to shoot the fluid out like it didnt want it and when checked for the head gasget and its fine and idk the thermostat may be messed up but even so i ran it without the thermstat and it takes awhile to heat up but it still ends up over heating so idk...
Old 12-09-2010, 04:09 PM   #4 (permalink)
How did you check for the headgasket?
Also does it only overheat when sitting still or does it overheat while driving down the road? Do your radiator fans come on?
Old 12-09-2010, 04:10 PM   #5 (permalink)
ALSO AVAILABLE IN SOBER
Zembonez's Avatar
Gameroom cash: $618331
View Zembonez's Photo Gallery
Have you done a compression and leakdown test? You could have a blown headgasket.
Zembonez is offline   Reply With Quote
Old 12-14-2010, 03:30 PM   #6 (permalink)
no i havent done a compression leakdown check.. but theres no oil mixed in with the radiotor and theres no coolant in the oil and it just over heats most of the time when the car is not moving it goes up and down so idk it doest shoot out fluid until the motor is really hot but it rarly happens so idk whats going on?????
Old 12-15-2010, 03:39 PM   #7 (permalink)
Gameroom cash: $147537
Where does the coolant shoot out? Did you do a flush to remove rust? Does the system hold pressure when engine is hot?
Old 12-16-2010, 10:49 AM   #8 (permalink)
from the radiotor and yes ive done a flush already to remove anything IF there was anything in there and idk if it hold pressure when its hot
Old 12-18-2010, 04:29 PM   #9 (permalink)
From rad? From the cap? Aftermarket cap or from Toyota. Try another cap.
You need to tight the cap. After engine heat up, the rubber hose will become hard. If they don't, you have a leak somewhere.
