Possible that a belt slipped in the tire or the alignment may be a bit off. As for bushings, most are pressed in a can't be replaced seperately or as with the case of the rear end, they are spherical bearings rather than bushings. I couldn't sway find bar mount bushings when I had to replace mine, but was able to replace them by just googling "17mm moog sway bar bushings" (you may have a slightly different size) and crossed the number to a cheaper brand at an autoparts store to a brand that I didn't mind hacking up. the only difference was that the part number I found were about half an inch too tall, I just cut them down and they have worked great ever since.
'11 Kawasaki Ninja 250R, '12 Mazda2
