5SFE Timing Questions
Hello,
My wife has a 93 Celica GT Convertible, recently the timing belt decided to break clean in half. After replacing it and a few other items I accidentally set my timing to 5 degrees BTDC. And I have noticed it accelerates like my 3/4 race cam 280zx n/a. No power until 2000 rpm's then once you hit 3000 rpm's the car actually tries to pull hard. Now the transmission is automatic so it shifts at 5000 rpm's but im thinking if it was a manual it would pull all the way to at least 6000 rpm's.
I'm going to adjust it to 10 degrees after TDC but I was wondering has anyone with a turbo'd celi has ran it with degrees BTDC? And did they like it, did it pull harder higher in the rpm's. And if anyone is a timing guru and would like to lay it on me please do and thanks.
