Need Help on Celica 2000 GTS rear wheel bearing hub - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-17-2011, 02:05 AM   #1 (permalink)
View chantura's Photo Gallery
Please, I need ur professional assist.
I had an accident on my Toyota Celica 2000GTS and now i have to change bearing on its rear wheel.
I have such question: Are a rear wheel bearing hubs of the Toyota Celica 2000GTS and 2000GT the same or they are different?
Ur rapid answers will be highly appreciated.
Thank u in advance
chantura is offline   Reply With Quote
Old 01-17-2011, 10:09 AM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
After comparing part numbers yes they are. The only thing to take into consideration is do you have ABS on your GTS? if so you need to pull a hub from another car with ABS. If you do not have ABS, it shouldn't really matter if the hub is from a car that has it or not.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 01-18-2011, 02:23 AM   #3 (permalink)
As I was told there are some other differences between brake discs and for this reason it is impossible to mount bearing hub of 2000GT to GTS. Is it right?
Old 01-18-2011, 02:17 PM   #4 (permalink)
Well if you swap only the hub, there shouldn't be any issues, however if you swap over the rotor or any brake components and all then yes there will be a problem. The exact same parts were listed for both GT and GTS as far as the wheel bearing is concerned.
Old 01-24-2011, 11:23 AM   #5 (permalink)
RobMilkshakes
Thank u for ur help
