3S-GTE Oil Pump - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-20-2011, 10:58 PM   #1 (permalink)
View drugal's Photo Gallery
3S-GTE Oil Pump
Here's the story: I'm doing a timing belt change on a 2nd gen 3S-GTE, and figured I'd spin the oil pump since the engine hasn't been run in a while. I could hear oil moving around, but none reached the cams up top, as the speed was slower than idle. I then noticed oil coming out of the hole near the crankshaft as shown in the picture. That hole normally has a retainer pin/bolt thing screwed into it for the timing belt, but was removed to change the belt.
So I'm wondering if I blew a seal doing this, or if this is normal with that pin removed. Any ideas?
1987 SV21 3S-FE
1990 SV21 3S-GTE RC
drugal is offline   Reply With Quote
Old 01-21-2011, 12:00 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
That pin has nothing to do with the front oil seal. Not sure why you had to remove it to change a timing belt. You shouldn't have to.
If you've got a leak there, you should go ahead and replace the pump while you have it apart.
These guys on Ebay have new ones for about $60.00. I bought one from them last year when I replaced the one on my MR2.
3sgte oil pump
The Jedi Speeder at CarDomain
