Hard to start after a fender bender? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-14-2011, 08:33 AM   #1 (permalink)
01 Solara/00 Sienna
Cranky-Condor's Avatar
View Cranky-Condor's Photo Gallery
Hey all....
My boss also has Toyotas and his daughter is having issues with her 2000 Celica. Someone rear ended her and did some minor bumper damage which has been repaired but now when she goes to start it, she has to turn the engine over for a "long" time before it starts. Appearently it runs fine once started, it just takes a "long" time to start.
First thing I thought was some kind a fuel pump/check valve type issue or a fuel line leak where the fuel was running back into the tank and took a while to pump back to the engine....
Anyone very heard of this happening and are there any other possible solutions? Thanks!
Warren
2001 Solara + 2000 Sienna
Cranky-Condor is offline   Reply With Quote
Old 02-15-2011, 09:36 AM   #2 (permalink)
Rabid Teddy
Ace2424's Avatar
View Ace2424's Photo Gallery
If it is cranking strong, I would say fuel. What could have happened is the impact shook the fuel tank and if she hasn't been buying the best gas all the time, there could be sediment in the tank that got shook up and is now clogging the strainer.
I would also check connections and also look at the front end under the hood. It is possible for the car to shake so much that even stuff up front could come loose.
Super White 1994 Celica GT 5SFE 5-Speed - 150,000 Miles - Still Driving
Vintage Red Pearl 1999 Camry 5SFE - 216k Miles - Totaled R.I.P.
Ace2424 is offline   Reply With Quote
The Following User Says Thank You to Ace2424 For This Useful Post:
Cranky-Condor (02-15-2011)
Old 02-15-2011, 10:47 PM   #3 (permalink)
View renatodato's Photo Gallery
Could be just coincidence. Try jumping it to see if it starts right away. If it does, it's just the battery/charging system. If it's been in the shop, the battery could have been drained. Shops are notorious for leaving accessory lights on, draining the battery. Although, I don't know the nature of the fender bender, depending on the impact, anything can happen. Try the simple fix first. Jump it.
renatodato is offline   Reply With Quote
