as frustration has set in...
1991 Celica GT Hatchback, 2200.
typically, however not guaranteed, when car is going between 65 and 70 it will start to loose power after a distance. If we let off the gas it will eventually regain itself, but knock back down when it's back up to 65-70-mph. If it gets real bad, we pull over, turn it off, and restart it. However if it happens, it's next occurance will be sooner, and sooner ,etc.
There have been occasions where it will do it no matter what.
Have replaced :
Clutch
Fuel pump
Distributor cap, rotor, wires, plugs, coil wire
HO2 sensor on exhaust manifold
HAve had it in - they can't find it - no codes - no check engine light....
WE ARE GOING NUTS !
please help.
