1988 celica gt idle problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-24-2011, 10:41 AM   #1 (permalink)
View bshoults1's Photo Gallery
Hi,
I misposted this, I have a idle problem, i replace the air intake hose with flexable hose and then when i started the car it backfired and blew a hole in the hose and know the car wont idle, any ideas?
bshoults1 is offline   Reply With Quote
Old 02-26-2011, 12:56 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Have you replaced the blown hose with the proper hose yet?
The Jedi Speeder at CarDomain
Old 02-27-2011, 07:31 AM   #3 (permalink)
Not yet, I have it on order. I did replace the mass air flow meter and now the car idles, idles high - around 1300 then drops to around 900 when in gear. I also found that I have oil in the distributor cap.
Old 02-27-2011, 08:48 AM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Which engine do you have?
Old 02-27-2011, 08:52 AM   #5 (permalink)
what engine
I cant read the tag, but it looks like it is a 3s-fe
Old 02-27-2011, 09:01 AM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
OK. Oil in the distributer can cause all kinds of idle and running problems as it fouls up the spark.
I believe there's an O ring at the base of the distributor where it meets the head. Replacement should stop the problem. Timing will have to be reset after the distributor is reinstalled.
Old 02-27-2011, 09:06 AM   #7 (permalink)
Yea, I replaced the distributor cap. I am not a car person so all of this is new to me. I know it is very hard to get parts for this car. Is the oil ring easy to get and what is involved in replacing it - I have a haynes manual, but haven't seen anything on the oil ring, will look again. I like this car though and want to get it running right.
Old 02-27-2011, 09:20 AM   #8 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I'm not familiar with the 3sfe. But most of the earlier model Toyotas use an O Ring at the base of the distributor. It's a matter of removing 2 bolts, sliding out the distributor(note it's rotor postition) , remove the old O Ring, sliding the new one on, putting the distributor back, and then retiming the engine and locking down the distributor..
Anyway, hopefully, someone here with the same engine will confirm the distributor type.
Old 02-27-2011, 09:23 AM   #9 (permalink)
Actually, there are four bolts holding the distributor on, after that I haven't a clue where the oil ring is. just have to look and hope for the best.
Old 02-27-2011, 03:42 PM   #10 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
The distributor itself should only be held in by two bolts. This is an aftermarket distributor but you can see the o ring. I have also PMed you a diagram of a 5SFE distributor (it is essentially the same)
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 02-27-2011, 04:11 PM   #11 (permalink)
Thanks, i ment that the cap has 4 bolts, yea i think that the distributor needs replaced. I will do that during the upcoming week. right now i have the idle right and the car seems to be running okay. but I still need to replace the distributor. the pictures help alot, thanks!!
