Thee distributor could cause the engine to not run, but will have no bearing whatsoever when it comes to the starter. If you only hear a click when you turn the key and do not hear the whine of the strarter spinning the engine then its either the battery does not have the amperage to turn the starter over, or the starter motor itself has died. Its a good idea to check the cables, battery terminals, and ground points, but most likely you just have a faulty battery or starter.
Most autoparts stores do bench tests of starters and batteries for free, if you have transportation to one, just pop the battery out and go have it tested, that'll give you a lead in the right direction.
'11 Kawasaki Ninja 250R, '12 Mazda2
