Keep in mind you'll have to do a lot of research. You currently have a 7AFE engine, and other A series engine with swap in using the same mounts and transmission, but will still require a wiring harness and ECU swap as well. You can also swap to S series engines, but much more work is required, a mount has to be moved as well as needing a different trans, axles, etc on top of the engine, harness and ECU, but I have seen it outlined in good detail on celicatech (4AFE -> 3SGTE IIRC). The most popular by far is the 3SGTE swap, but 4AGZE, 4AGE (16v & 20v), 3SGE, 3VZFE, and 1MZFE have all been done as well as hybrid engines, such as 7AGE, 5SGTE etc.
That should just about cover all the bases.
'11 Kawasaki Ninja 250R, '12 Mazda2
