1992 Celica GT oil pressure issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2011, 08:12 PM   #1 (permalink)
View doug2060's Photo Gallery
1992 Toyota Celica GT Convertible
2.2 5SFE 201,000 miles on car and 80,000 miles on used engine
5 speed manual transmission
I just discoved a problem with my Celica. I just got a tag on it this past Monday and have been able to drive it. It does have a bad oil leak but not severe. I haven't had a chance to fix it as I had to leave it at the trim shop to get the top reconditioned. I suspect it's coming from the oil pump. The engine was replaced with one from a local junk yard with 80,000 miles on it. I do not know how long this engine sat before being installed in my car. I drove the car to my moms house probably 10 miles away and on the trip back (about 18 miles into the round trip) the oil light started to flicker. It seemed to flicker more as I accelerated. I went home and checked the oil. It was to the full mark. The oil was just changed and has less than 30 miles since changed. I went ahead and changed the oil filter and the oil pressure sending unit since it was cheap. I drove the car about 5 miles and it started flashing again but much sooner than the first time it did it. I'm using 10w 30 oil. I can turn the car off and wait just a minute or two or just 30 seconds and start it back and the light is not coming on but after a couple minutes of driving it will return and slowly begin to flicker until it stays solid with random flickering. Any thoughts or opinions or personal experiences are greatly appreciated.
doug2060 is offline   Reply With Quote
Old 03-06-2011, 10:45 PM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
Honestly, what you described does sound like dying oil pump, either clogged or has just lost efficiency.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 03-06-2011, 11:13 PM   #3 (permalink)
Being that the engine was on a shelf for possibly many years could the screen on the pickup tube just be clogged?
Old 03-07-2011, 11:58 AM   #4 (permalink)
I just took the valve cover off and what I saw scares me. There is crusty burnt up oil all over the place. It's around the spark plug tubes and the side of the head toward the front of the car. The stuff is very ash like but oily. It's like burnt sludge I guess. If this stuff got washed down to the oil pan it would have to be blocking the oil pumps pickup tube screen for sure.
Take a look and tell me what you think...
Old 03-07-2011, 12:06 PM   #5 (permalink)
Yeah I think you may have a plugged screen.
Old 03-07-2011, 01:43 PM   #6 (permalink)
More photo's below... I got the oil pan and pickup tube off. I cleaned the screen off just a bit with carb cleaner. It didn't appear to be overly clogged up but was covered with this debris. The pan was thick with the stuff to the point that it dumped out in clumps. I should have took a photo of it before but you can clearly see this crap all over the inside of the pan. There is no way in hell this is an 80,000 mile engine... Can 80,000 miles really look like this?
I can tell someone has been in here before. The oil pump has clearly been replaced at some point and the pickup tube had rtv silicone instead of a proper gasket. It was probably losing pressure at where the pickup tube bolts to the oil pump as the rtv appeared to be pushed out and hanging. I will make a new gasket from a sheet of oil resistant rubber fiber and clean this crap up as best I can. I can't be 100% sure this is my problem but it damn sure looks that way. Any and all thoughts and opinions are welcome here.
Old 03-07-2011, 09:40 PM   #7 (permalink)
It could certainly be an 80,000 mile engine, depending on how long it sat or what maintenance (or lack there of) its had while in use.
Old 03-07-2011, 09:50 PM   #8 (permalink)
Thanks, I used RTV to seal the oil pan because I'm sure I'll be back in there. I'm going to wait till morning to fill it back up and test it out. I cleaned it up the best I could but I know theres lots more hiding in there.
Old 03-07-2011, 10:12 PM   #9 (permalink)
Bitter's Avatar
Gameroom cash: $559600
View Bitter's Photo Gallery
I can't help but wonder if that's coked oil from overheating. You learned an important lesson, don't install it until after you've dropped the pan and pulled the valve cover. If I had seen that, I'd have sent it right back to them under the 30 day warranty and demanded another one. 80k miles or not, that engine may not last...especially if thats coked oil from a bad overheat. It may be in your best interest to send some samples of that hard crap and sludge off to be analyzed, I'm not sure if Blackstone Labs can test stuff of that nature...email them and ask. $25 a sample, $25 to save you time/money when they tell you its full of bearing metals and is burned to a crisp.
Old 03-08-2011, 09:16 AM   #10 (permalink)
RESOLVED: ....... I hope...
I would have to say it appeared to be sludge build up in the top of the motor on the side that is tilted upward. It does appear that it had been cooked over the years. From what I hear sludge build up is common in these engines when not properly maintained. I did not find significant amounts of metal shavings in the oil pan but I did see some. This is a concern for me along with the extreme amount of deposits. I have notified the junk yard of the problem and they have agreed to extend the warranty to 90 days. I let the car sit overnight so the RTV sealing the oil pan could set up. I filled it back up with 10W-30 and drove the car several miles without so much as a blink of the oil light. I plan on changing the oil again VERY soon and each time I do it over the next few months I plan to drop the pan and pickup tube for cleaning.
While I was at the junk yard they showed me a similar engine from a Camry with 120K. They took the valve cover off and it was far worse than mine was. The guy tried to tell me they are all like that... BS... The bad thing about it was they are actually planning on selling that motor to someone knowing about all that crap in it. I think I'll be buying my used parts elsewhere in the future. Oh yeah, He also let me know my engine had been sitting on the shelf since before they got their computer system in 2002 so there is no telling how long it actually sat around. I guess I can look forward to changing all the seals very soon too but I kinda expected that anyways.
I know I didn't receive a whole lot of help on the several forums I have visited but it's good to take a break and vent frustration through a keyboard. It really gives you time to think and come up with options. Hopefully my posts can help others throughout the interweb with shit filled Toyota engines... LOL...
Old 03-08-2011, 07:16 PM   #11 (permalink)
Bitter's Avatar
Well good luck....Might be seeing an engine rebuild thread from you.
Old 03-09-2011, 01:11 PM   #12 (permalink)
I doubt that... I have no plans on rebuilding this engine if it does crap out. I just don't think the car is worth doing that. I would like to think that I (may) have made the condition managable with proper care. Other than looking decent the car still needs a lot of work. There is an oil leak possibly from the oil pump oil ring or seal. The suspension is crap too and it needs tires immediately. There is some good news... According to papers left in the car the clutch and pressure plate was replaced just 6 weeks before the original engine blew it's head gasket. It will also be needing brakes. Once these issues have been addressed and the engine is fully cleaned out I will probably sell it. With summer coming soon it shouldn't be hard to sell a convertible.
