Turbo for 1988 celica GT-S - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2011, 09:57 PM   #1 (permalink)
View celicawizerd's Photo Gallery
4th Generation Turbo for 1988 celica GT-S
Hey I was wondering if it was possable to put a toyota celica alltrac turbo in my 88 celica GT-S? and anyother ideas on where i could get a turbo kit for this car and a little bit on how to put it all in...
THANKS celicawizerd!
celicawizerd is offline   Reply With Quote
Old 03-06-2011, 10:42 PM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
Yes, you can swap the engine. You have a 3SGE, the alltrac uses the 3SGTE. Research up on what engine codes mean, and what all is involved. Extremely short version: engine, wiring, ECU, as well as any small things that may need to be swapped over. plenty of information is out there by many people who have done the work. As for a turbo kit, usually the only cars that they are put together for are only the most popularly modified ones and often times you can do better buying seperately, mostly you'd have to gather everything yourself.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 03-06-2011, 10:52 PM   #3 (permalink)
What i mean is the engine in my celica can i put the all trac turbo on it? with out having to swap the engine?
Old 03-10-2011, 05:45 AM   #4 (permalink)
View MrJim's Photo Gallery
possibly.. but ECU / harness would be different. the ECU would be tuned to the 3SGTE. if your compression is off on the 3sGTE it's not a correct tune. GL.
MrJim is offline   Reply With Quote
Old 03-10-2011, 08:06 PM   #5 (permalink)
View mightrolla's Photo Gallery
Yes bolts up just fine. Get the ecu tune for you have higher compression.
mightrolla is offline   Reply With Quote
