rough idle, lagging acceleration
I have a '91 Celica GT convertible with the 2200 4 cyl., automatic transmission. It currently has 112,000 miles. I have recently done a fuel injection cleaning, throttle body cleaning, air and fuel filter replacement, timing belt, oil pump, water pump replacement. New plugs, wires, distributor, (cap, rotor and a rebuilt distributor) The TPS sensor seems to be operating properly. The car is running good but not perfect. When it is in drive and just idling it's rough, the steering wheel is shaking noticeably. While driving on the freeway at 50 mph or so it seems to lack power. I have to push down to passing gear to get acceleration power. I replaced the oxygen map sensor with a map sensor from a salvage yard out of a supra about a year ago, same part number. Any suggestions about what I might check or what this may be? Thanks.
CP.
