Originally Posted by pga88
Yea I'm still in the dark. I took to Toyota today. They said its the body ecm. So guess ill be
Shopping around as they want 1000 for new and 500 for refurbished one. That's crazy.
If you'd like a second opinion, I could do some diagnosis where I work. Give us a call on Monday and setup an apointment, we're in Hazel Crest IL. Top Gun Auto, 708 335 2271. You'll probably speak to Cindy and she'll let me (Jordan) know. Worst case scenario is that Toyota is right, even if you just go with Toyota I'm still very curious to know the exact failure, which output or input is not responding. If its just one output not working, like to the head relay or one thing like that, it could be 'repaired' by using a relay in place of the body ecu control. Actually, check out newcelica.org and ask about how to wire the car for direct control of the headlights. You may find that someone there can make the relay harness to bypass the body ecu controls which you can install yourself and fix it for much much less.
I'm not here trying to make money off you, I'm here trying to help you fix your car.
