Check Engine Light code p0171 system too lean bank one - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2011, 07:09 PM   #1 (permalink)
View angzua93's Photo Gallery
Can someone please help me, i scanned my check engine light and it came up with code p0171 system too lean bank one. Can someone tell me what i need to fix and how much it will cost?
angzua93 is offline   Reply With Quote
Old 03-28-2011, 07:17 PM   #2 (permalink)
Posting via iPhone/iPad
CupCate18's Avatar
Gameroom cash: $373364
View CupCate18's Photo Gallery
Clean your MAF sensor. Brake parts cleaner is your friend. If not, check your fuel filter and replace if needed.
RWD 5-speed Zoom-Zooms
My car has less body roll than I do.
When you want sports car handling, you buy a sports car.
CupCate18 is offline   Reply With Quote
Old 03-28-2011, 08:01 PM   #3 (permalink)
View TECH 1's Photo Gallery
check for a vaccum leak.
TECH 1 is offline   Reply With Quote
Old 03-28-2011, 09:41 PM   #4 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
What model do you have OP?
If you're going to clean the MAF, actually use the stuff designed for it...
I'd check for vacuum leaks, as tech 1 suggested, any possible leaks around the intake manifold, or possibly an EGR diaphram could be stuck open. Unmetered air entering will be the most likely culprit. While the engine was running did you have any issues with drivability or any noticeable differences?
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
