Bad fuel pump - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-08-2011, 09:53 PM   #1 (permalink)
View allened's Photo Gallery
Bad fuel pump
I was wondering, Would a car just die while driving down the highway if the fuel pump goes out?
The rpm's just dropped to 0 and I cant get the car to start, cranks but no go. I have replace the igniter, coil, and just did the cap and rotor, the distributer resistance is good.
I have just never had a bad fuel pump and was wondering if it did go bad would something like the scenario above occur?
allened is offline   Reply With Quote
Old 04-08-2011, 09:56 PM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
yes. Have someone turn the key to the ON position, listen through the filler cap, you should hear the pump kick on. Or, test for voltage going to the pump.
Also, did you check your timing belt? you never addressed that in your other thread.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 04-08-2011, 10:00 PM   #3 (permalink)
I think I will do a voltage / resistance test, as I dont have anyone to turn the key for me.
I just wanted to make sure that it was even a possibility before I took out the back seat.
Old 04-08-2011, 10:02 PM   #4 (permalink)
baby joker
View babyjoker33's Photo Gallery
check to see if you have spark,take one of your plugs off,and the spark plug. leave the spark plug in the wire, also set it on the top of the engine and turn the key like your trying to start it have some one with you to see if they can see it if you have spark.
babyjoker33 is offline   Reply With Quote
