5sfe to 3sfe swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-24-2011, 11:25 AM   #1 (permalink)
View Redneckin82's Photo Gallery
5sfe to 3sfe swap
I recently swapped out a 5sfe from a 94 camry into my 91 celica gt. After completing the swap my engine wouldn't start and after some troubleshooting I found out the distributors are different. If I go from a 5sfe to a 3sfe, will I need to change over my distributor? I am under the impression everything is interchangeable but I have a feeling this distributor will be a problem and I'd like to know before I get a knew motor.
Redneckin82 is offline   Reply With Quote
Old 04-25-2011, 12:05 PM   #2 (permalink)
Gameroom cash: $147537
Whenever you're swapping the S series, keep all electronic parts on the car being swapped into. So keep all electronic from the 91 GT. Just use the distributor from the 91 GT. It doesn't matter which 5S-FE or 3S-FE you're swapping. Do not try to cut any wire or changing plugs.
Tags
3sfe, 5sfe, camry, celica, distributor
