converting a 2000 automatic gts to a manual - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-04-2011, 09:32 PM   #1 (permalink)
View raifarmstrong's Photo Gallery
USA converting a 2000 automatic gts to a manual
Hello, I own a 2000 Toyota celica gts. It's an automatic however I want to convert it into a manual. I'm I just need to know what parts are needed to do the switch. Any input is appreciated. Thanks alot!
raifarmstrong is offline   Reply With Quote
Old 05-05-2011, 10:01 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
From the inside cabin to the transmission: Clutch pedal, pedal spring, stick shift,shifter boot and plate,shifter cable linkage, clutch master, hydraulic line, clutch slave, mounting bolts for slave and lines, transmission, pressure plate, clutch disc, flywheel,throw out bearing, bearing retainer clip and axles. Not sure if axles fit hubs, so you may need the hubs too.
Have fun with your project and welcome to TNation.
The Jedi Speeder at CarDomain
The Following User Says Thank You to MR2Jedi For This Useful Post:
raifarmstrong (05-05-2011)
Old 05-05-2011, 01:23 PM   #3 (permalink)
Thank you very much for your help!
Tags
2000, 2zz, celica, gts, manual
