Izzy problems!
I have a 1.8l 1zzfe that has been rebuild because of the oil consumption problem. Right before it was rebuilt, it became extremely sluggish and was popping po300, po302, and po171 constantly. When the motor was torn down #2 cylinder had a burnt valve, rings were stuck, and carbon everywhere. All bearings were in spec, but they were still replaced. Pistons, rings, timing set, and plugs were replaced. I am still getting a sluggish acceleration, and popping codes po171, and po300. I have tested the injector resistance, seemed ok. Tested spark, seems ok. Tested the wiring harnesses, cleaned the maf, intake, and checked all of the vacuum lines. Not sure what to try next as its the first yota i've worked on.. any tips would be much appreciated.
