Need help please - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-09-2011, 07:52 PM   #1 (permalink)
View venomous's Photo Gallery
Need help please
I have a 2000 celica gt...my motor is making a loud knocking noise at all time..the other day it completely stop working. it started back after a couple of attempts... i think i need a new motor but idk...wat kind of motor will fit and how much or wat can i get for the car if i sale it..
venomous is offline   Reply With Quote
Old 06-14-2011, 10:22 AM   #2 (permalink)
techtalk's Avatar
View techtalk's Photo Gallery
Hey man,
Ouch! From the symptoms you've described it sounds as though your Celica has developed the dreaded rod knock issue that sometimes afflicts older 1zz engines. I've read that you could replace the engine with one built in 2003 and above because they don't seem to have this problem as frequently as the older 1zz engines do.
Would it be insensitive of me to suggest a 2ZZ-GE engine swap at this point in time?
techtalk is offline   Reply With Quote
Old 06-14-2011, 08:46 PM   #3 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
The 1ZZ-FE engines (what came in your car) made from 2003 and onwards had redesigned piston rings to lessen the oil consumption that plagued the early 1ZZs. You may want it professionally checked out to make sure that is what actually happened as your post is a little vague, to say the least. You would need another 1ZZFE engine if what techtalk and I suspect is true. If you were to sell it with a blown engine, I would expect you could probably sell it for about $1500 or so depending on the market in your area and the condition of the car. If I had a little extra cash, I'd probably make you an offer myself depending on the shape of the rest of the car.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
