1993 GT Still overheating. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2011, 04:02 PM   #1 (permalink)
AW_CelicaGT's Avatar
View AW_CelicaGT's Photo Gallery
Gen5 1993 GT Still overheating.
I changed the radiator and thermostat, changed the coolant, and my fans work. however, whenever i take the car for a short drive, the temp goes up. I stop the car and shut it off, it steams near th coolant tank. it sounds like its almost boiling.. Suggestions?
Life is way too short to drive slow...
AW_CelicaGT is offline   Reply With Quote
Old 06-10-2011, 07:13 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $559600
View Bitter's Photo Gallery
get all the air out?
Old 06-10-2011, 08:56 PM   #3 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
Might want to swap the radiator cap as well. If they go bad they wont allow the system to pressurize. If the system is not pressurized it will lower the boiling point and allow the coolant to boil.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 06-11-2011, 12:27 AM   #4 (permalink)
93 Camry LE 5S-FE
4Cyl'erThriller's Avatar
Gameroom cash: $428796
iTrader Score: 15 reviews
View 4Cyl'erThriller's Photo Gallery
I doubt this is your problem but Ive heard of people installing the thermostat backwards or incorrectly and that will cause problems. Might be worth a look. If its backwards it will be stuck closed so, Its not hard to check, it might be worth a shot.
4Cyl'erThriller is online now   Reply With Quote
Old 06-23-2011, 02:09 PM   #5 (permalink)
PEN
PEN's Avatar
View PEN's Photo Gallery
if it still over heaters get
New:
*water pump
*radiator cap
check to make sure nothing is causing blockage as well
Cheers to a nicely tuned car m8
PEN is offline   Reply With Quote
Old 06-23-2011, 02:31 PM   #6 (permalink)
93 Camry LE 5S-FE
Check this thread. It might help, seems like a similar problem.
5SFE overheating... I'm stumped
Did you check the thermostat?
