Hi Bozu,
Sounds like you want to put the 3S-GE engine into a rear wheel drive car.
All S series engines had the same engine to bellhousing bolt pattern.
So, any bellhousing from an S series engine can be bolted to any other S series engine.
The Corona ST140 (with 1S engine), Corona ST141 (with 2S engine), Celica SA60 (with 1S engine), Celica SA63 (with 2S engine) and Caldina (with 3S-GE engine and 6 speed manual gearbox) are all RWD and have bellhousings that can be bolted to a 3S-GE.
Those bellhousings will all bolt W55/56/57/58 gearboxes - the main difference between them are the ratios.
The bellhousings and gearboxes from front wheel drive cars (eg St160) are not suitable for a RWD car.
If you are putting the 3S-GE into a FWD car then you will need a gearbox from a FWD car (eg Celica ST160, ST180, ST200).
Which car are you putting the 3S-GE engine into?
- Stepho
