ignition issue 1994 celica gt
ok so I just rebuilt my 5sfe in my celly after throwing a rod through the block and unfortunately, though it starts I have two major issues that need to be resolved that I cant figure out, first my ignition timing, though my crank and cams are correctly timed I run out of timing adjustment on my distributor leaving me only getting to about 16 degrees when as I'm sure you know I need ten degrees
now my idle is high even at operating temperature so that could be part of it, but my throttle is completely closed as far as the cables are concerned so I don't know how to remedy it idling at about 2000rpm
the other issue is my radiator fans aren't starting when it reaches or passes normal operating temp
any help or suggestions would be greatly appreciated seeing as how this was/is my daily driver
