Pressure blew cam seal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-20-2011, 09:07 PM   #1 (permalink)
View just_ee's Photo Gallery
I have a 1991 ST. Recently the timing belt stripped some teeth. I changed the belt. While I was in there decided to change the water pump, cam seal, crank seal, valve cover gasket, spark plug seals, etc. The next day the cam seal blew and I began losing alot of oil.
Wondering if anyone has any ideas about why this happened. I figure I now need to change the pcv valve, but still curious if the major pressure change could be something else...
just_ee is offline   Reply With Quote
Old 06-20-2011, 10:41 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $559600
View Bitter's Photo Gallery
Probably didn't get the seal installed just right.
Old 06-20-2011, 10:54 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
^ Strong possibility. I would also check to make sure the valve cover vent tube is not obstructed.
The Jedi Speeder at CarDomain
Old 06-23-2011, 05:05 PM   #4 (permalink)
I changed the cam seal (again), pcv & vacuum line. Blew the cam seal again. At least thats what it looks like. Too disgusted to look for a day or two...
Old 06-30-2011, 02:43 AM   #5 (permalink)
z3n
View z3n's Photo Gallery
worst comes to worst, it might be a broken ringland. my friends alltrac kept on blowing cam seals even after having them replaced numerous times. do a compression test to see what your numbers are. my friends numbers didn't come out to well..
z3n is offline   Reply With Quote
Old 07-04-2011, 12:05 AM   #6 (permalink)
Gameroom cash: $147537
The PVC valve is alot easier to blow then cam seal. You need to hammer the seal in. Also the dip stick will blow out first also.
Old 07-08-2011, 10:36 PM   #7 (permalink)
Rabid Teddy
Ace2424's Avatar
View Ace2424's Photo Gallery
Did you axle grease the seal before install? If you don't, the camshaft will rip right through that sucker.
Super White 1994 Celica GT 5SFE 5-Speed - 150,000 Miles - Still Driving
Vintage Red Pearl 1999 Camry 5SFE - 216k Miles - Totaled R.I.P.
Ace2424 is offline   Reply With Quote
