help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2011, 05:50 PM   #1 (permalink)
View GleepGlop's Photo Gallery
help
Hey i am new to working on cars. SO i think my water pump went out on my 1991 celica gts, there is a large water leak where the bottom hose from the radiator connects to the what i presume is the water pump or thermostat, can anyone tell me if i am on the right track
GleepGlop is offline   Reply With Quote
Old 06-23-2011, 10:03 AM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
that would be the thermostat housing
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 06-23-2011, 01:36 PM   #3 (permalink)
PEN
PEN's Avatar
View PEN's Photo Gallery
Few things, is it leaking from the hose? If so adjust it have came loose. Another I hope its coolant not water cars don't use water bro go buy some coolant for that car $12. Also if your thermostat did go bad they are made to stay broken open so your car doesn't over heat but they don't leak as far as I know. Hmm try adjusting the hose and re tighten it check for cracks and small holes, do this when the car has cooled down though. Good luck
Cheers to a nicely tuned car m8
PEN is offline   Reply With Quote
Old 06-23-2011, 04:37 PM   #4 (permalink)
thx rob, i was just confirming.
No pen its not the hose, the leak is coming out of one of the seams on the thermo.
I'm going to be getting into it this weekend, if you guys think of anything else i could use some more input.
thanks
Old 06-23-2011, 05:47 PM   #5 (permalink)
if its coming from where that housing meets the block, I would just check to see if its cracked (unlikely), if not replace the seal and reevaluate.
Old 06-24-2011, 01:09 AM   #6 (permalink)
PEN
PEN's Avatar
oh okay I see let me know if you pin point the fault and leme know your solution ^.^
