Thanks / Follow up
Rob - I would very much appreicate the testing procedure.
Btter - It's a 2.2.
I'm going ahead and replacing the ignition coil. I already replaced the control module that sits up against the firewall. The ignition coil sits within the distribution assembly.
Do you happen to know if I need to remove the entire distributor to replace this module? I've removed the distributor cap, rotor, and shroud. So I can see the ignition coil, but can't see a way to remove it without taking the whole distributor off.
I'm okay to do that if needed. I just wanted to avoid having any chance of messing up the timing. I can mark it and so forth, but history tells me, despite best instructions, I have some personal mental block on setting up timing.
Thanks for your help.
Jon
