High RPMs on Highway - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2011, 09:41 AM   #1 (permalink)
View luisantoniof's Photo Gallery
gen 7 High RPMs on Highway
Hello, I have a 2000 GT with over 120K miles on it.
The car works perfect, just a minor issue with O2 Sensor that I am going to replace soon
My question is, when I'm on the highway going around 70 to 90 miles on fifth gear, her RPMs are about 4K to 5K, is that normal??
Is there a way to reduce them??
Thanks
luisantoniof is offline   Reply With Quote
Old 06-30-2011, 05:32 PM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
90 for prolonged periods?! jeez.
Anyway, that sounds about right, they're closely geared and usually sit around 3k rpm or so at 55-60, so 4k at 75 sounds about right to me in the highest gear. Keep in mind that cars are usually designed to get optimal gas mileage around 55-60mph and are geared accordingly.
The GTS transmission, although a 6 speed is just geared slightly closer so not much improvement would be seen.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 06-30-2011, 07:27 PM   #3 (permalink)
90 but not for long just when there is no cops around, even though I have taken her in 4 hour drives and she works fantastic.
The reason I asked is because my girlfriend has a 2003 corolla, and if I'm not mistaken it has the same engine as the celica (1zz), and at 70 miles it sits around 3K rpm
Old 06-30-2011, 07:59 PM   #4 (permalink)
Well what transmissions are in each? auto or manual?
Old 06-30-2011, 08:48 PM   #5 (permalink)
Bitter's Avatar
Gameroom cash: $559600
View Bitter's Photo Gallery
normal, short gears and s somewhat short differential give better acceleration but higher rpm's while cruising at highway speeds. It's fine for the engine to hang around 3-4K rpm for hours at a time btw. corolla has wider taller gears for better fuel economy.
Old 07-01-2011, 06:27 AM   #6 (permalink)
The corolla is automatic and the celica is manual.
So the high RPM are ok on the celica.
Ok so I will not worry then, although it feels like the corolla has higher acceleration but maybe it is just because Im not changing gears
Old 07-01-2011, 07:48 AM   #7 (permalink)
Bitter's Avatar
clean the mass airflow sensor in the Celica and if it's over 90K miles change the spark plugs as well.
Old 07-01-2011, 03:04 PM   #8 (permalink)
Thanks, Done
