Irratic Idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2004, 09:12 AM   #1 (permalink)
View 91GTS's Photo Gallery
Irratic Idle
My 91 GT-S will speed up and slow down at idle, between ~200 rpm and ~1000 rpm. This seems to happen when it gets warmed up. It pulls fine, with no missing. Sometimes it will die at a stop. This car had sat for about a year. Any ideas? Can this be computer diagnosed? Thanks.
91GTS is offline   Reply With Quote
Old 05-17-2004, 09:19 AM   #2 (permalink)
Gameroom cash: $147537
Its the idle control valve. Reset idle and timing. Remove battery -ve terminal for a minute to reset ECU may help. Also try clean TB before all of the above action.
Old 05-17-2004, 10:07 AM   #3 (permalink)
thanks. The throttle body looked pretty dirty.
Old 05-17-2004, 04:08 PM   #4 (permalink)
Then remove the hose one at a time and spray throttle body cleaner through the hole into the TB. For sure you'll need to remove -ve from battery and reset idle + timing after cleaning.
Old 05-18-2004, 07:15 PM   #5 (permalink)
Blane's Avatar
View Blane's Photo Gallery
Mine does the samething but doesn't the engine doesn't die.
Blane is offline   Reply With Quote
