If the fan motor is grounded, regardless of the a/c switch being turned on, as long as the ignition is in the run position, and/or the car is running, the condenser fan turns on....I pulled the ac condenser fan relay and checked for voltage....it is a 5 pin relay...two of the pins have voltage with key on...engine running or not....a/c switch on or not. This appears to be a system that has the control/switching on the ground side.
I have good continuity in both wires going from the relay socket to the fan motor...I have two wires with voltage available....but the relay never trips...have tried swapping the regular fan relay (which appears to work as normally expected...fan kicks on and off (cooling fan, that is) and regardless, the swap of the relays didn't change anything. So I suspect there is a ground completion not being made somewhere at the control end.
John
Originally Posted by Bitter
if you turn the AC on and simply add ground to the ground wire of the fan, does it run? at the motor I mean.
