https://picasaweb.google.com/lh/phot...eat=directlink
i used my hands to push the seal in about a millimeter or two and then used the pipe fitting and bolt technique to gradually press the seal in using the cam's own threads. this is my second attempt, and i'm not sure the results are much better than using the flipped cam cog technique.
in both cases there was one section of the edge that got pushed up by the bore and looks a bit screwed. last time it was the upper right corner, and in this case it is the upper left as you can sorta see in this photo.
can anyone tell me if this is gonna leak, or should i go to get another seal and try yet again?
thanks!
