90 celica gt leak help
Okay thanks to robmilkshake's help the first week of September I will be completely replacing the transmission, and the flywheel while adding a new stage 2 clutch kit. Also replacing the shocks all around =).
Okay now to the problem, I don't know exactly where or what fluid or fluids it is yet. it seems to be leaking oil from the oil pan drain bolt also it seems to be leaking coolant too from somewhere behind the oil catch pan area. I did not change the water pump when the timing belt snapped but it looks like some water corrosion on the pump itself. are these common problems and what will solve these leaks?
thanks.
Cheers to a nicely tuned car m8
