I assume this is for a 3sfe (like what is in your siggy) so it will be very similar to a rev1 5sfe. You will need engine management with both fuel and timing control. Depending on which engine management you use and how much power you are shooting for will determine what size injectors you will need. With a 50 trim t3/t4, I would go with 360-400cc injectors. Be aware that is a big turbo that will not spool until after 4000rpms on your engine.
Also add a larger fuel pump and better clutch to your list as well as a MAP sensor.
Originally Posted by PEN
*oil feed lines "need to know where to drill in the pan and where the feed line goes"
Oil can be sourced from a T at the oil pressure sender or a sandwich plate at the filter. Oil return can be done by using a 3sgte oil pan or drilling your pan in the same place and adding a fitting. It needs to be as high up on the pan and should be a large size hose. Hopeful the one that comes with the kit will be good. Also make sure the oil feed has a restricter in it so it doesn't overfeed the turbo.
*engine fuel pressure regulator "no idea how to install or it works"
You don't actually need this unless you plan to use it to slightly raise or lower the effective size of your injectors. Even if you use one I wouldn't change base pressure by more then 10psi or so as it causes problems. If they include a rising rate FPR and assume that will be enough to get a good tune don't believe them.
*boost controller
If you can get one that has an over boost protection feature to open the wastegate fully should you over boost past a set limit. Unfortunately they are kind of pricey. The one that comes with the kit is probably just a simple cheap mechanical one which will be fine if you are careful.
*adjusting the compression ratio "any idea how to do that?"
You do this with custom forged pistons or a thicker head gasket (not the best way). With low boost you will not need to though as long as you have a decent tune.
If I miss anything let me know ill be boosting on low psi so I wont need internals. is there a way when I put it on to make it smogable?
It will fail visual but with a good tune will still pass a sniffer test. In some states this is completely illegal.
Also I understand I can instal an oil catch can that comes with the turbo kit instead of running lines into the turbo and oil catch pan.
A catch can just helps remove some of the oil that comes out the PCV vent on the valve cover. When you hook up the PCV hoses you are going to need to run them to a place before the turbo. The vacuum sources on the throttle body and intake manifold are going to see boost so any PCV hoses that go there will get blocked off to keep you from blowing oil past the turbo seals.
Lastly since I am assuming this is for a 3sfe it probably has similar limitations to the 5sfe. That means that you will not be able to safely go past about 250whp without changing the ring end gap. With a 50 trim t3/t4 that is somewhere around 12-14psi. Any higher and you risk binding the rings in the cylinder and breaking pistons.
